  #1111 (permalink)
Old 12-20-2010, 05:02 PM
David Kirkham's Avatar
David Kirkham David Kirkham is offline
Original Shelby Owner
Originally Posted by David Kirkham View Post
Differential 2
Differential with axle housings and bearings.
This differential case had the OUTER pinion bore machined over sized. If you want to bore it out and sleeve it you can save a very expensive case. The differential unit is a 19 Power Lock--the same unit used in an original car. The axle housings are copies of the original with the taper roller bearings. You will have to clean or replace the bearings.
Differential case $2000
Side axle housing with bearings $300 x 2 for $600
Power Lock Differential $475
Retail $3075
Today $900
$800
Now only $700
