Just replacing the rubber lines
Chas, you're right I want to replace the rubber lines only. I will raise the rear of the car and remove the driver rear wheel and hope I can reach the hard line out to secure a new rubber line. I reached up there once and I was not sure I could remove and secure a new rubber hose but I will try again. If not, Iguess I will need to remove the tank as suggested.
Chas, I want to connect my new pump to the frame HP filter like you have done. Is this assembly inside the trunk?
Bob, ever thought about making a bracket large enough for a fuel pump and filter connected together on a plate that has a 90 degree tab on the backside that was predrilled for the tank mounting holes? We could mount the pump and filter on the plate and then bolt the plate (using the 90 degree flange) to the tank mounting bolts. Nice and neat with no fiberglass or frame rail drilling!
