Old 12-20-2010, 09:56 PM
Double Venom's Avatar
Double Venom Double Venom is offline
Wetdog,
Knowing you as little as I do, I don't believe you of all people would ask this question?
I can't find a single fault with the listed posts.
Cooler: Wash and flush with acetone/lacquer thinner, boil cooler, then flush immediately with cold water under the highest pressure you can get.
Use an automotive paint filter-put the filter in a funnel, pour the water out of the cooler using the funnel.
Blow the cooler dry.
Now go back to the filter, take a magnet to the sides and the bottom-
Use a large magnifying glass and visibly inspect the filter again.
ANY metal, babbitt material, sell it on e-Bay! Better yet throw it away!
What let loose?
