My understanding of transmission gears in general is that wide ratios were more commonly used for street use and close ratios were for road racing use. Close ratio transmissions typically have a big jump in gear ratio between 1st and 2nd, allowing 2nd, 3rd and 4th ratios to be closer together. On a road track where you only start from a stop once and seldom slow enough to use anything below 2nd, it allows the driver to more easily keep the engine RPM in the peak torque range.
Tommy
Previously owned EM Cobra
