Old 12-21-2010, 07:46 PM
vector1 vector1 is offline
Cobra Make, Engine: jbl
with the closer fitting hub/rim the tire has to be put on with the holes lined up pretty close, you can't spin the rim on the hub or have any wiggle room. i don't see any benefit if there is no other reason. the rim does rest on the hub protrusion when the wheel is mounted and the lugs can be inserted fairly easy with the lug-centric. just a fyi
