Old 12-21-2010, 08:40 PM
mikeforte mikeforte is offline
Smile Throw out bearing
Hi Roger,
Without measuring the forks I can't tell if you have a 1 3/8" pressure plate. Do you have a 3 finger long or diaphram? If so you could use a large 1 3/8" fork and bearing. With those I make a press-in sleeve to fit a TKO or small input Top Loader.
Originally Posted by RodgerH View Post
I have an FE, Lakewood 15210, and TKO600 (1-1/8" 26 spline), with a D0TZ-7515A clutch fork.
Which replacement throwout bearing is the correct one?
I tried a Federal Mogul FB-1625-C. It works, but it seems like the distance between the forks is slightly wider than the machined flats on the throwout bearing holder and allows the holder to rotate slightly. It might be OK, but I would rather find one that fits more closely.
Anyone know the correct bearing?
Thanks,
Rodger
Forte's Parts Connection
40 Pearl St
Framingham, Ma. 01702
fortesparts.com
508 875 0016
In 1993 Mike made the first conversion of a Ford Tremec to GM 5-speed. It bolts to stock bellhousings w/out an adapter. The FE Tremec, the Mustang adjustable quadrant are originals from Mike.
One of 12 Tremec Elite Distributors worldwide for: T-5, T-56 Magnum & TKO-500 & TKO-600 ,Midshifter, Frt shifter, offset Vette shifter.
Est: 1981 selling performance parts to build your dream car...
