Old 12-22-2010, 05:54 AM
RodgerH RodgerH is offline
Cobra Make, Engine: SPF 2592, Shelby alum. 527
Originally Posted by mikeforte View Post
Hi Roger,
Without measuring the forks I can't tell if you have a 1 3/8" pressure plate. Do you have a 3 finger long or diaphram? If so you could use a large 1 3/8" fork and bearing. With those I make a press-in sleeve to fit a TKO or small input Top Loader.
Hi Mike,
Thanks for the reply, but you lost me. What should I measure to determine the 1-3/8" dimension? I have a Centerforce diaphragm pressure plate.
Rodger
