Old 12-24-2010, 04:32 AM
Default Check the end play also
RestoCreations. Check the end play on the camshaft also with it installed in the block. If you are using a torrington bearing, this is real important. If the play is too much, the camshaft will walk around inside the motor and speed up the wear on the distributor gears and put extra stress on the distributor shaft and driving the oil pump. Rick L.
