Old 12-26-2010, 05:03 PM
elgecko's Avatar
elgecko elgecko is offline
Cobra Make, Engine: Scratch build......a little every day.
Default B&M auto shifter neutral switch
Installing a B&M auto shifter that has a micro neutral safety switch.
Can I wire this up with the 12 ga. wire coming from ign. switch S post , into the micro switch and then to the firewall mounted solenoid switch for the starter?
Will the micro switch handle the amps? The switch has a rating of 15amps.
If not, can a relay be installed.
I do have a 12v, 30amp 4 post relay laying around.
Thanks
Dave
55 mph is unsafe at any speed. Huh?
