Old 01-18-2002, 11:11 PM
Bish Wheeler Bish Wheeler is offline
Cobra Make, Engine: A&C 427SC #188 ZZ4 Crate, Tremac 3550
Send a message via AIM to Bish Wheeler
Todd,
With the power you are running those 28 spline axles are the weak point and if they "go" it's gonna tear things up. Then you can add a towing charge on top of everything else.
If you can afford the swap then for sure you should do it. The street performance will sure be more enjoyabe. I didn't have a locker in my car before, but the posi was pretty worn and the left axle had a twist in the spline. I switched from 3.23 gears to 3.70. It made all the difference and only upped my 70 mph rpm by 350. 'Course you're running a lot more power than me, so your gearing is probably just fine at 3.20. My $.02 worth.
Bish
