Old 12-27-2010, 12:19 PM
Z-linkCobra's Avatar
Z-linkCobra Z-linkCobra is offline
Cobra Make, Engine: Everett Morrison, All aluminum small block ford.
I have to agree with FWB on this one. YOu can only flow so much fuel through a jet in a carb. The needle and seats are desigen to flow more fuel then the carb can flow at wide open throttle. Unless your fuel lines are smaller than your needle and seat....tell me why you need more fuel flow.
Its a supply and demand type senario....the demand will never exceed supply unless your running 1/4" fuel lines....and if you are then you need your head examined...lol.
I like the idea of the down stream regulator....but think its over kill.
Just my 2 cents worth.
" If it wont break em loose in 3rd gear, it aint enough power "
