With a minor leak in the combustion champer often times you will see it on the plug that will have a green tinge. You may also look for the recent thread covering a members issue with a head gasket leak from a stripped head bolt, that resulted in a small leak into the lifter valley. Since it appears you have a iron block it could be a small head gasket leak into the lifter valley.
Reason: Correction
