Old 12-31-2010, 02:31 PM
dcdoug's Avatar
dcdoug dcdoug is offline
Default Replacement visor bracket
The mounting bracket on my sun visor that the allen set screw threads into is stripped, cheap metal that it is. I know that you can buy a full mounting kit from Finishline for $60, but is there anywhere I can but just a single bracket?
Also, does anyone know if the Finishline set is higher quality metal? Maybe I should replace them all, but I'd rather not do it with the same old crap so the problem happens again in a year.
I'm sure most of you have solved this problem. So the solution is?
www.partskeeper.com
