If the timing is too far advanced, it can make it harder for the starter to turn the engine over. However, before you start fixing something that may not be broken, why, other than your starting problem, do you think your timing may be off? Do you know what your timing numbers are (i.e., idle without vacuum advance, and at 3500 RPM)?
Tommy
Previously owned EM Cobra
