Old 01-03-2011, 06:49 PM
Hitch's Avatar
Hitch Hitch is offline
Cobra Make, Engine: BackDraft Racing 351W bored and stroked to 427 hydraulic full roller
If your turn signal switch is anything like mine I would advise against bending the pot metal that it is formed from. I'm not sure that even heating it would be a good idea. On mine though the switch is mounted to the steering column mast via a set screw. If you loosen the column and slide it towards you then you could loosen the switch set screw and move it away from you. JMO...
The cruiser and the bruiser... you decide...
http://img.photobucket.com/albums/v1...e/IMAG0417.jpg
