01-06-2011, 08:49 PM
Ca.
Originally Posted by thefordguy
the problem with the steering angle is that the power steering pump is right in the way. The steering is just mocked up right now, nothing is set in stone. My original plan was to add another u joint and a heim joint. I have them already, but I haven't figured out where to mount the heim joint which is why I tried it without. where did you mount yours, I can't really tell in the pic? I noticed your alternator is on the opposite side as mine and it's a GM style , what brackets did you use for mounting it on the drivers side?
I made my own bracket because I did not like that there just was not enough adjustment on the passenger side. It is a GM 1 wire alternator.
Terry
"I may be paranoid, but that doesn't mean they are not watching me"
