This should be about a 540 to 550HP engine if all machine work correct and assembled right and the camshaft degreed right. Should be in the 530 to 540 ft/lbs of torque range again depending where the camshaft is degreed. You should end up someone where around 35 degrees on the timing. You will also see some power with a Super Sucker spacer if you have hood clearance. Watch what header you use so that you do not cover the exhaust ports on your heads. Try to get headers that are at least 1 3/4 that use the wide bolt pattern, 1 7/8 would be better. good luck.
Keith Craft
Keith C
