  #30 (permalink)
Old 01-06-2011, 11:15 PM
Rick Parker's Avatar
JWD If you are in California and your car is registered as a 1965 and was not manufactured in 1965 regardless of what it is parading around as, I suggest you introduce yourself with the Amnesty bill that is aimed at violators such as yourself. When the DMV and BAR refocus on this issue after much procrastination, there will be no second chances. Authorities will be knocking on your door to do inspections and revoke your plates on the spot, this is what is set to happen. I've seen it happen on a small scale. Currently it's just a money hunt, they have been, and are still refering to it as it an Amnesty Period. .....If you are in California and any of this applies to you I'd call it a Wake Up Period. THEN you can show everyone your 1965 (whatever) as it sits in the garage,or point to it through a fence at an impound yard. Because if it is registered as a 1965 and is not, or better yet if it is using the VIN of a legitimate 1965 IE: Mustang, Falcon etc whether it is a Cobra or not.........you'll be minus a 1965 (whatever).
Rick
