  #23 (permalink)
Old 01-08-2011, 04:16 AM
Default I don't hate but he's hitting things
philminotti Phil A PRO rally car setup should give this driver the abilitity to control this car to the inch. Paddel shifter, hand brake to rearend, AWD which in his case doesn't seam to be working unless there is a cutoff switch. How many takes where done to get this film? You can see that in some spots there was some multi takes done. Can he drive a car yes, but hit 2 things and maybe more. R/R tire was rubbing the body at one point and then stopped. As far as going though tunnels at high speed, we have to hole in the wall tunnels on street roads that are just wide enought to drive a dually though with about 3" on each side. The road is cobble stone with pot holes. You slide around in it because the road is always wet in side. The town is on a hill and water run off goes next to the tunnel. 50' and 1 row of 4' 40w bulbs inside for lighting.
Phil If he done the clip without hitting anything or on 1 take, different story. We have monster truck that can do everything he did AND BACK FLIPS. Ken's if that's his name is not there yet. Rick L.
