Old 01-20-2002, 01:07 PM
427sharpe's Avatar
427sharpe 427sharpe is offline
Cobra Make, Engine: A CSX Cobra,1966 GT350 and an '06 Ford Heritage GT
Post
This is very close to the pattern I used, but I did use ss rivets. Have never had a problem with the glass--just remember that when drilling the hole for the rivet, use a very sharp bit at high speed and drill the hole slightly oversize. For example, use a bit about 1/32 to 1/16th larger than the rivet size. If you can get to the rear of the rivet, and it will be hidden, it helps to use a stress washer as well--which is a small ss washer that goes on the underside to spread the load out a little.
"I think we have more machinery of government than is necessary, too many parasites living on the labor of the industrious." Thomas Jefferson
