  #23 (permalink)
Old 01-13-2011, 10:18 AM
YerDugliness's Avatar
YerDugliness YerDugliness is offline
Cobra Make, Engine: Cobra Auto Works body, Ron Godell Racecars chassis, 1989 Mustang GT 5.0 HO (converted to carb), W/C T-5, 3.73's in a Ford 9" Traction-Loc.
Loud "clunking" noises from under the car can be very disconcerting, but they don't always mean loose or missing parts.
If you have a "TractionLoc" differential, and it is low on lubricant, it will "grind" or seem to make "clunking" noises, most often when you are turning a corner. Check the grease level in your differential and fill it up if it's not full already, and don't forget the special "Limited Slip" treatment that is needed.
Cheers from Dugly
YD,E./PNB
No names were changed to protect the innocent!
