Old 01-21-2002, 06:31 AM
Clois Harlan's Avatar
Clois Harlan Clois Harlan is offline
Default Rad Hose
Go pick up a Gates hose #21143. You will only want to use the part of the middle that has all the turns you need. This was a problem for me as well.
I still don't like my lower radiator hose the way it is fitting. Everything was fine until I chose to use the Edelbrock water pump which has a 2 1/4" hose connection. If anyone has a part number on their lower radiator hose I would sure appreciate the number.
Clois
"Let's roll"
"Be part of Something Good
