Old 01-21-2002, 07:24 AM
BrianPaul BrianPaul is offline
Clois,
I have a 428 also and I am experiencing a leak from my 7 qt Canton pan. I am not using a windage tray so I am using one gasket. The leak is coming from the rear of the pan just inside of the outside of the first stud from the left of the block. It does not run down the pan but seems to whick over to the backing plate of the bellhousing. Is yours doung the same thing? I used the Blue stuff but to no avail. THis is the second time I have had this problem. Fortunatly the engine is still on the test stand. Any ideas?
Brian Paul Prokop
