  #56 (permalink)
Old 01-17-2011, 06:54 AM
Stentor's Avatar
Stentor Stentor is offline
Cobra Make, Engine: CSX 4000; Shelby aluminum FE with 58mm IDAs
Originally Posted by decooney View Post
...for the three radial units I was researching, the only difference in the specs was the tread pattern and lettering on the sidewalls; exact same compound and composition on all three tires - all made in the US by Cooper Tire Co.
Duane,
Based on your research, does Cooper produce the Avon CR6ZZ tires that are used on Cobras (it appears that they might based on the link you provided)? And do the Avon CR6ZZs have a similar tire that's made by Cooper?
Thanks,
Stentor
