  #29 (permalink)
Old 01-18-2011, 11:02 PM
Outwest34au's Avatar
Outwest34au Outwest34au is offline
Cobra Make, Engine: Evans kit, 6 litre, 6 speed, Jag F/R,
If the wagon master cylinder is the same in bore size it might be easier to just swap out the main spring in the proportioning valve. Even if you score a totally stuffed master cylinder the spring would be unlikely to be damaged.
You could shim or shave springs but even I wouldn't stuff around with that, the time and testing wouldn't be worth it.
The local wrecker (emerald) was doing a car collect and crush before xmas but the weather got him, if he has xf wagons with masters in the pile I will grab them for whoever needs them. I'm hoping he will be back out here this weekend coming if the weather holds.
Missed my Cobra budget by thaaaat much.
Ya get that on big jobs.
