FE Roccker arm kit
Hi Brian,
I sell the Harland Sharp rocker arm kits. Excellent quality and price. I have never had any failures.
Do you have stock non-adjustable or adjustable rockers? If non adjustable, you'll need pushrods...
Originally Posted by brianski
I have a SPF with a high performance 428FE. Unfortunately, I snapped a rocker arm yesterday after a nice wine country drive through Livermore CA. I also learned that this is a common problem with this motor. In the short time since it happened Ive been doing some research and it looks like there are a lot of names out there with more robust designs.
Can anyone recommend the best possible set to put on? Dove is a name that has come up a couple of times
Thanks!
Forte's Parts Connection
40 Pearl St
Framingham, Ma. 01702
fortesparts.com
508 875 0016
In 1993 Mike made the first conversion of a Ford Tremec to GM 5-speed. It bolts to stock bellhousings w/out an adapter. The FE Tremec, the Mustang adjustable quadrant are originals from Mike.
One of 12 Tremec Elite Distributors worldwide for: T-5, T-56 Magnum & TKO-500 & TKO-600 ,Midshifter, Frt shifter, offset Vette shifter.
Est: 1981 selling performance parts to build your dream car...
