I've had a lot of good luck out of the PRW rockers. They come in either aluminum or stainless, hardened shafts, billet stands, etc. The aluminum ones are very affordable at about $450 for the set. They come with rocker studs and all the hardware.
If you want something that's on the equivilent of the Erson rockers that are no longer available, T&D just started making their version of the Erson setup. They are $925 with shipping.
If you're running a flat tappet cam or a hydraulic roller, a lot of the aftermarket setups out there would work fine. Just make sure that they have good end stands as part of the package.
