Old 01-21-2002, 12:52 PM
rbray rbray is offline
Default Pressure Plate bolt questions
I finally got my bellhousing aligned and now I'm ready to bolt up the pressure plate and disk. I have a 351 crate motor and the flywheel has three sets of four bolt holes. My Centerforce plate has a variety of holes drilled and I am at a loss as to which ones to use.
Also is it necessary ( I'm guessing that it is ) to use special pressure plate bolts or can I use grade 8 bolts instead?
Thanks,
Roger
One more question. How can I tell if the pressure plate is properly aligned?
Roger
