Old 01-23-2011, 07:32 AM
mickmate's Avatar
mickmate mickmate is offline
Hey Mark I have seen two types of Jag side plates. The CW link you have above shows the type that have caliper bracket bolt holes out the front of the plate(like Jeffs). The other two types I have seen use the front and top holes of the five for a caliper bracket. They have longer bolts in those 2 holes and will just accomodate a caliper bracket behind the output flange. The caliper bracket bolts are what I've been using for diff mounting brackets. My thinking is the car stops faster than it accelerates hence the strength of brake calipers being quite up to the job of mounting the diff.
mickmate
http://www.actoncustom.com/
