Old 01-25-2011, 07:49 PM
mikeforte mikeforte is offline
Smile Speedo drive
Hi Dan,
I make a speedo drive and have gears that fits into a Top Loader (Jerico & David Key), TKO or Ford T-5. This speedo drive is made to use a GM speedo drive.
I also sell a cable and gear to work in your Top Loader. I hope I can help with what you need.
Thanks,
Mike
Does anyone have a spare speedometer driven gear housing that plugs into the side of the toploader transmission, clamp, O-ring, etc in good shape? I'm more use to Muncie transmissions so I hope this description is close. Mine is missing. If so let me know what you want for it.
Thanks
Dan Clemans
dclem427@comcast.net
Forte's Parts Connection
40 Pearl St
Framingham, Ma. 01702
fortesparts.com
508 875 0016
In 1993 Mike made the first conversion of a Ford Tremec to GM 5-speed. It bolts to stock bellhousings w/out an adapter. The FE Tremec, the Mustang adjustable quadrant are originals from Mike.
One of 12 Tremec Elite Distributors worldwide for: T-5, T-56 Magnum & TKO-500 & TKO-600 ,Midshifter, Frt shifter, offset Vette shifter.
Est: 1981 selling performance parts to build your dream car...
