Old 01-26-2011, 03:54 PM
FWB's Avatar
FWB FWB is offline
Originally Posted by saltshaker View Post
I don" want to use solid motor mounts, so how do you secure the engine from torquring up? My side pipes on the drivers side has left a circular mark in the cut out ! Any pictures would help.......
Jon
jon,
i have two ideas, which are used on my car.
1st is buy motor plates and mounts from crites restorations, they make a OEM one and a heavy duty non-factory one, i used the heavy duty.
2nd put a little adjustable heim joint attached to the drivers cylinder head that goes down to the frame to keep the motor from torquing alot, this will also be an insurance policy for your hood in case of the mount letting go
Fred B
