I guess I'll need to go back and check the main caps and see if the blocks have the front cam main
oil galleries threaded plugs. I'm almost sure they did, but I'll need to check again. Also found some BBF Lakewood bellhousings and 5 or 6 Stewart Warner 240A elect fuel pumps. pumps appear to be working as I put power to them and had them wet started to a gas can so they didn't dry pump and poss ruin something. What would these be worth also? Just way too much to go thru for a non ford guy. I'm learning something new every day I go out there and research what is there.
