Old 01-28-2011, 09:55 AM
Wbulk's Avatar
Wbulk Wbulk is offline
Cobra Make, Engine: 66 Cobra
You don't say if the car has been run before with another engine. If it has then the problem would be with this engine/flywheel. If not, then it could be engine/flywheel, trans bearings, u-joints, rear axle pinion angle off. If it's solely based on RPMs and not speed, then that eliminates a lot towards the rear.
