Old 01-29-2011, 11:40 AM
Wbulk's Avatar
Wbulk Wbulk is offline
Cobra Make, Engine: 66 Cobra
Have you considered making your own mounts? It would seem that a mount with reduced movement would be the best of both worlds. A piece of .120 wall tubing with rubber bushings about 1/4" thick with tabs welded to it works pretty good. You can put two other tabs on an engine plate or the frame and then put a through bolt through the tabs on each side of the tube. I prefer to put the tubing with tabs welded to the frame and the other tabs welded on an engine plate. Hope this makes sense.
