5.1. The protective device shall be so designed that it is necessary to put it out of action in order to enable:
5.1.1. the engine to be started by means of the normal control; and
5.1.2. the vehicle to be steered, driven or moved forward under its own power.
5.2. The requirements of paragraph 5.1. shall be met by the single application of one key.
5.3. Except in the case provided for in paragraph 6.1.5. a system operated with a key inserted in a lock shall not permit removal of the key before the protective device referred to in paragraph 5.1. has come into action or has been set to act.
Most common practice for manufacturers to comply is an immobiliser for 5.1.1 and a steering lock for 5.1.2 both controlled by the one key.
