OK, I laz'd Boy after dinner and crashed! Didn't have time until now to try and post the following - here goes:
This is the 10ga. stainless plate I made to support the brake & clutch MC's - Mounted on the inside of the firewall
[IMG]
[/IMG]
Billett / Reservoirs Pre Mounted:
[IMG]
[/IMG]
This one is hard to make out. It is about a 10"x10" fiberglass piece that I fiberglassed to the inside of the fender. I then cut a piece of 1/8th'' steel about 12"s long x1/2" wide. Mounted it behind the new plate and the fender flange, then bolted it in tight. this should take care of any sagging or vibration of the reservoirs. (Photo's don't show it but this piece was sanded, primed and painted the color of the car.
[IMG]
[/IMG]
Mike (Forte) supplied Straight fittings for the reservoirs but due to my mounting I used 90' fitting- this is the way I set them up.
[IMG]
[/IMG]
[/IMG]
Reservoirs finally mounted - hoses still loose.
[IMG]
[/IMG]
Did the best I could on this photo. Shows the reservoirs in relation to the M/C's.
[IMG]
[/IMG]
And last BUT not least the inside of the trunk lid repaired, fiberglassed, painted and a stainless plate installed with Welded nuts for the license plate and holder.
[IMG]
[/IMG]
Hope my last 4 hours helps someone!
DV
