Some small progress. I find out tomorrow if the 3rd piston order will be correct. I sure hope so as the roller will most likely be more or less finished in the next week.
Special thanks to the Kirkhams for the scratch and dent sale-that saved me a bundle! I owe you guys more Scones!
The carpet smelled funky like cat urine, so it is now gone and will be replaced with some nice new fresh wool carpet from Kirkham
New Pedal Assembly
Removed the custom plate that was put in place to hold the steering shaft.
Throttle pedal assembly. One problem though, the holes on the bracket coming off the frame do not line up with the holes in the throttle pedal assembly box. Simple fix is i drill the holes a little bigger. However, i have one question; should there be spacers between the frame rail and the box to fill the void?
