Not sure if this should be in another forum, but was hoping to get a quick reply to my problem. Tried searching, but no luck.
I recently installed a new drive gear (internal on shift shaft) in my T5 to compensate for gear ratio change. I also replaced the driven gear. It worked fine for about 100 miles and now it isn't working. The gears ARE NOT chewed up.
I know the cable is good, because I can hook up a drill to the cable and the speedo works. I don't know if I am not installing the 16tooth gear incorrectly or what.
Everything seems to line up, but it just doesn't work. I'm pushing the driven gear over the end of the cable as far as possible and then putting on the clip. HELP!!!
