Clutch, Flywheel, Bellhousing for a 428
Need some help guys...
I have a 428 and plan to hook it up to a Tremec TKO transmission. I need a bellhousing, flywheel and clutch. I've pretty much settled on the Lakewood bellhousing and I would like to run a Centerforce Dual Friction clutch. Trouble is nobody seems to know whether Centerforce makes a DFC for the 428. Can this be done or should I look for a comparable McLeod clutch? Also, should I opt for a OEM steel flywheel or a new billet steel flywheel? Thanks for your help.
Ken
