Old 02-01-2011, 08:27 AM
mbeers6 mbeers6 is offline
Cobra Make, Engine: B&B,351w
Thank you for the reply gentlemen. As far as I know it's not a custom housing or cable. The car is a B&B, I purchased it used.
I will first make sure the drive gear is rotating, then check to see if the inside of the driven gear is rounded off. I think I could detach at the gauge and spin with a drill and if the driven gear moves then it must be seated okay I would think.
I'll also measure the length of the driven gear on the cable and see if it might be bottoming out against the housing inside.
At work now, but will look tongiht and post. THANKS FOR THE REPLIES!!
