I was working on a buddies 3cyl diesel powered tractor and after setting the valves, I started to wonder how or what determines the valve clearance?
I have fiddled around with different settings before on Cummins NT motors to run the timing up and down a bit but how are the original clearances determined? How would you determine clearances for an unknown performance cam shaft?
John
