On the clutch and brake there is a set nut on the back of the rod going into the master cylinder in the footbox. You can loosen this nut and then twist the rod in and out to raise and lower the pedals. The throttle does not have much adjustment due to the nature of getting open full throttle.
Good luck, James
Radical Roadsters of Texas LLC
www.radicalroadsters.com
Backdraft Racing Dealer
281-804-5730
Watch out! You may get BIT!!!
