Between .010 and .020 at the lobe/lifter end will usually get you reasonably close on a mystery cam.
The variables/limits are noise/impact damage at the large end and "no start" at the low end of the common ranges. A cam designer will also take lifter diameter, lobe profile grinding capability and durability needs into account when making the choice.
Survival Motorsports
"I can do that....."
Engine Masters Challenge Entries
91 octane - single 4bbl - mufflers
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
