Old 02-03-2011, 09:21 PM
Keithc8 Keithc8 is offline
A little loctite in places does not hurt. Any car that will get ran like these cars need checking over from time to time and it seems a little more when new. Double check all of the radiator hoses because they need to be tight and we like to run two on the end of each hose for extra clamping force. Water under one of these cars at speeds is no good and also will make a mess of your engine compartment. You have been given most all of the things that you can check and should. Take your time and you will find most of it to be ok but every now and then you find one missed, even by the best.
Good luck, Keith
Keith C
