Old 02-04-2011, 03:25 AM
blykins blykins is offline
My thoughts:
1. Figure out what rpm range you want to run in (or do the most running in) then build the engine for the most horsepower in that range.
i.e. If you're going to be doing nothing but 2000-5500 cruising, then build the engine for that rpm range.
2. Cobras have gas pedals. Even if you have "too much", you have a gas pedal and can control it.
3. Whatever your desire is, add a little bit more. As an engine builder and Cobra owner, I've found that you get accustomed to the car and you will want more power down the road.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
