  #201 (permalink)
Old 02-04-2011, 07:08 AM
Don Don is offline
Might be the 458 will be the Challenge model, note the changes:
" The V8 engine has remained the same, but important modifications have been made to the gear ratios and calibration of its dual-clutch F1 gearbox to guarantee higher torque at lower revs. "
" Ferrari’s main focus was to reduce the car’s weight. To do that the company used lightweight materials, such as carbon-fiber and Lexan for both exterior and interior. The new 458 Challenge also has a specific suspension set-up with solid aluminum bushings, stiffer springs, single-rate dampers, center-nut 19” racing rims, larger dimension Pirelli slicks and a ride height lowered by 30mm all round. "
" The 458 Challenge also gets a new F1-Trac traction control system that constantly monitors levels of grip for maximum high-performance road-holding. Two specific track-biased calibrations – wet and dry - have been developed for this application, with control logic and strategies derived from Ferrari’s extensive racing experience in the F1 and GT championships. "
http://www.topspeed.com/cars/car-new...e-ar93486.html
