Originally Posted by sideshow
u are all forgetting one simple thing
99% of cobras are manual
so not sure how u lock it in neutral
I wasn't suggesting to lock it into neutral, I was suggesting to lock it into reverse...the example I mentioned was a mechanical linkage, as suggested by Boxhead, but if that was achievable with a linkage 35years ago, I don't see why you can't do the same thing with a solenoid today.
when they say transmission lock and shifter lock im sure that relates to an auto trans
Not true - Section 6.3 of ADR 25 related to "Protective devices acting on the gearshift control"...
"6.3.2. In the case of manual gearboxes it must be possible to lock the gear shift lever in reverse only; in addition locking in neutral shall be permitted."
