Thread: Valve springs
Old 02-05-2011, 04:48 PM
Keithc8 Keithc8 is offline
You might want to check them because some of the Edelbrock heads come with pretty good spring pressures and you would not want to knock a lobe of the camshaft. If it is a new camshaft make sure you use a special break in oil or you will have problems.
Good luck, Keith
Keith C
