Misc parts for Superformance install...
Blaz: The picture shows the speedometer angle drive which is installed on the back of the speedo and to which you hook up the speedo cable to.
Other items I purchased (besides literally 5 pages of parts for the individual engine parts, bell-housing, clutch, pressure plate, flywheel, throw-out bearing, clutch slave and trans):
Battery
3 Ύ Hole saw (to cut hole in console for shift lever)
Heater hose support clamp (mounted on inner fender-well)
Speedometer cable
Brake / Clutch fluid (Dot 3)
Engine motor mounts
Nose, trunk and side emblems (Shelby/ 427)
Driveshaft
Rear trans mount
Fuel line hose (connection from hard line on chassis to fuel pump)
Hose: expansion tank overflow to puke tank (coolant overflow recovery bottle)
Floor mats from Finishline
