The tricky part (to me anyway) is that the ignition starter relay activates an earth circuit to the lamp, much like the brake fail switch, whereas we normally use relays to control positive circuits. Eg, headlights, fans, etc.
Hope this makes sense.[/quote]
Yep a relay will do it or you could have a Falcon ignition switch that fits nicely on the Laser steering column that has an auxillary contact that you can earth to do the job. Works for me.
